yamaha dtr 125 starting problems
PAPAMACK
This post is 6146 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi all new to this so any help would be much apreciated. i have a husqvarna wr125 with a yamaha dtr 125 engine in it but i cant get the bloody thing started. i am 90% sure it is not a electrical problem as the engine was running when i bought it and im getting a good spark. currently has no air filter on so was convinced had dirt in carb/jets but when i went to strip carb down noticed some berk had rounded the screws and i cant get them out any suggestions?thanks
Link to comment
Share on other sites
Had a similar issue, went to strip the carb down and screw heads sheered...the only way i could think of getting them off was to drill the heads off (set the drill so you are drilling anti-clockwise i.e. as though you were loosing the screws it also loosens them)....it works but BEFORE you do it make sure you have some spares to put back in their place.
Also maybe wait to see if anyone has any less destructive ideas ;)
Also, make sure you don't slip and mess the carb up!!!!!!!!
Link to comment
ok thanks pedz. ill give that a go managed to get two of them out so at least its just one to try drilling. thanks again and i will let you know how i get on.
Link to comment
  • Recently Browsing
