DT175 Oil light switch
I have a 79' model DT175 which I'm getting ready for registration.
The oil light (2 stroke tank under side cover)is on all the time.
I have pulled out the switch and checked the operation of the contacts which seem OK.
The switch has 3 wires going to it ( I could not work out why it needed 3 wires?) and on closer inspection I found that there is a diode inside a resin type of plug in the top of the switches rubber top.
I checked the diode and it seems OK. ( I'm an Electrician)
When I disconnect the diode the switch works OK.
I would like to know what the diodes purpose in life is??
Why would you need a diode across what should be a simple switch??
Thanks Mark
  • 2 months later...
i have a DT 125 R
and my oil light is on when its in neutral,
its nowt to worrie about, i have to addmit its abit anoyying after abit
hope that helped u out....
