XJ650 throttle sticking
Just purchased my XJ650 tried to ride it bur found when the engine gets warm I cannot slow the engine tick over down. I would apreciate any help.
check throttle cable for free play, you need some. Tickover is set at the carbs, its between the 2 centre ones just below the carb air inlets about 1 pence in size. i would also check to make sure cables are free to move, should not take any effort at all, and that they are not caught up any where like under the tank.
Thanks for that I will adjust it this morning.
