March 1, 200818 yr there is a height adjustment on the rear shock. if u look at the bottom mounting on the swingarm there is a nut and bolt loosen them and put it up a notch (or down if needed) i tink there is about a 15-20 mm adjustment eiether way on it . just while im here u got any ideas for an aftermarket exhaust for a 2007 model
June 3, 200917 yr there is a height adjustment on the rear shock. if u look at the bottom mounting on the swingarm there is a nut and bolt loosen them and put it up a notch (or down if needed) i tink there is about a 15-20 mm adjustment eiether way on it . just while im here u got any ideas for an aftermarket exhaust for a 2007 model your back suspencion has one more hole i tried in mine it goes way up as for exhoust try arrow
