Posted December 28, 200717 yr The indicators and hazards on my 2001 TDM 850 have stopped working, They were fine until last friday when half way home the indicators started to work sporadically but now nothing at all. Thought maybe a relay but apparently the hazards and indicators are on seperate relays so (apparetnly) the chance of both going at the same time is rare. Any advice would ne of great help, fitted a set of heated grips 2 weeks ago. don't know if that would make a difference, they do not go through the wiring ciruit thay are straight connection to battery.
December 30, 200717 yr Author They might be on seperate relays but might be on the same fuse. They are on the same fuse which is fine, also when activating or deactivating the alarm, the indicators flash.
