TW 125
Is there an alternative carb that can be fitted to a TW125 other than the TEIKEI Y24P? Mine seems to hesitate when you open the throttle and cut out, but when it is running it runs ok any ideas? thanks.
Sounds like a rich cut. When you open the throttle there is too much fuel getting through and the engine cuts out.
If its a diaphram type carb, then there is a hole in the diaphram.
thanks I'll get it checked out
  • 2 months later...
Hi desso,
are you still interessted in a new carb?
I have 2 TW125 (one with a upgade to 200ccm and one with 220ccm) and I've made a onlineshop (tw-parts.com) for our BigWheel.
I have 2 carb kits for the TW.
Here is the link to my shop.
It's in German, but I've added the google translation.
