Posted December 20, 200717 yr Is there an alternative carb that can be fitted to a TW125 other than the TEIKEI Y24P? Mine seems to hesitate when you open the throttle and cut out, but when it is running it runs ok any ideas? thanks.
December 20, 200717 yr Sounds like a rich cut. When you open the throttle there is too much fuel getting through and the engine cuts out. If its a diaphram type carb, then there is a hole in the diaphram.
December 21, 200717 yr Author Sounds like a rich cut. When you open the throttle there is too much fuel getting through and the engine cuts out. If its a diaphram type carb, then there is a hole in the diaphram. thanks I'll get it checked out
February 26, 200817 yr Hi desso, are you still interessted in a new carb? I have 2 TW125 (one with a upgade to 200ccm and one with 220ccm) and I've made a onlineshop (tw-parts.com) for our BigWheel. I have 2 carb kits for the TW. Here is the link to my shop. It's in German, but I've added the google translation.
