TDM 900 Overheating problems
Hi All,
I have a 2003 TDM 900 that seems to have an overheating problem in slow traffic or after coming into slower traffic after a decent run. The fan seems to come on eventually but not until the temp ind is right up to the top of the gauge and can cut out on over temp'.
Can anyone help with some ideas or tips, please?
Many thanks, Chris
Assuming that you have some coolant in it (check the level cold) then it could be that the temperature sensor is not working properly.
I dont know if the fan signal is from the guage needle or has its own sensor but you need to check. Another thing to check is that the radiator fins are clear and not blocked to the airflow.
