December 3, 200718 yr Have just spent most of my working day reading the forums....not sure my boss would be too happy but it has thrown up another question....two in one day. I have a 1998 DTR which has a seperate bottle for the 2 stroke so i don't have to premix. I filled it up and have only been out on the bike twice doing a total of about 40 miles, if that, and used about two thirds of the bottle. Is This Right? Am i using too much oil and if so can it be checked/adjusted etc Thanks all
December 3, 200718 yr your using way to much oil there fella. bet its smoking like mad. i would be checking your pump asap to see how wrong its set.
December 4, 200718 yr Author She is smokin like a good 'un yeah Smells nice though!! How do i go about adjusting the pump, any ideas....as i said i am pretty new to this lark. Cheers
December 4, 200718 yr She is smokin like a good 'un yeah Smells nice though!! How do i go about adjusting the pump, any ideas....as i said i am pretty new to this lark. Cheers folow the st piping down to the engine case it should go in behind a cover. open this up and have a look. should really explain itself once youve looked. ive never worked on a dtr but all the 2t's ove worked on have setups that work along the same lines.
December 4, 200718 yr Author folow the st piping down to the engine case it should go in behind a cover. open this up and have a look. should really explain itself once youve looked. ive never worked on a dtr but all the 2t's ove worked on have setups that work along the same lines. Thanks gav2k, i'll take a look over the next few days and let you know how i get on! Cheers
December 10, 200717 yr You should be getting roughly 400 miles out of the 2-stroke bottle, so ive been told . So i guess 40 miles and you went through so much is amazing, smokie bike.
