Posted November 19, 200717 yr Does anyone know the oil capacity of YL1 transmission? And also what weight of oil it uses.
November 19, 200717 yr rderricknc said: Does anyone know the oil capacity of YL1 transmission? And also what weight of oil it uses. Isn't it printed in your owners manual?
November 21, 200717 yr Author yoda said: Isn't it printed in your owners manual? If I had a owners manual I wouldn't be asking the question.
January 3, 200817 yr rderricknc said: Does anyone know the oil capacity of YL1 transmission? And also what weight of oil it uses. I have a yl1 and manual it says use 30 detergent oil just under 1 pint they put seven eighths of a pint or a little less than half a quart in gearbox
January 15, 200817 yr Author southwold22 said: I have a yl1 and manual it says use 30 detergent oil just under 1 pint they put seven eighths of a pint or a little less than half a quart in gearbox Thanks for the information
January 17, 200817 yr southwold22 said: I have a yl1 and manual it says use 30 detergent oil just under 1 pint they put seven eighths of a pint or a little less than half a quart in gearbox this quote is in the Yamaha riders manual for yl1 in the service manual it says one and three eighths pints or 650cc .not sure which is right
