November 19, 200718 yr Does anyone know the oil capacity of YL1 transmission? And also what weight of oil it uses.
November 19, 200718 yr Does anyone know the oil capacity of YL1 transmission? And also what weight of oil it uses. Isn't it printed in your owners manual?
November 21, 200718 yr Author Isn't it printed in your owners manual? If I had a owners manual I wouldn't be asking the question.
January 3, 200818 yr Does anyone know the oil capacity of YL1 transmission? And also what weight of oil it uses. I have a yl1 and manual it says use 30 detergent oil just under 1 pint they put seven eighths of a pint or a little less than half a quart in gearbox
January 15, 200818 yr Author I have a yl1 and manual it says use 30 detergent oil just under 1 pint they put seven eighths of a pint or a little less than half a quart in gearbox Thanks for the information
January 17, 200818 yr I have a yl1 and manual it says use 30 detergent oil just under 1 pint they put seven eighths of a pint or a little less than half a quart in gearbox this quote is in the Yamaha riders manual for yl1 in the service manual it says one and three eighths pints or 650cc .not sure which is right
