Posted November 14, 200717 yr just got a dt125x took it up the road and there is white smoke coming out of it. what could it be??
November 15, 200717 yr just got a dt125x took it up the road and there is white smoke coming out of it. what could it be?? ummm... if it were a liquid cooled car, i would assume that you were burning off coolant, but im not sure what it would be on your bike.
November 15, 200717 yr ummm... if it were a liquid cooled car, i would assume that you were burning off coolant, but im not sure what it would be on your bike. i guess you mean out the exhaust. this is normaly a sign of burning oil. not sure if your 4 or 2 stroke, if your 4 stroke could be worn valve stem or rings. if it stops after a couple of minutes dont panic yet..
November 15, 200717 yr just got a dt125x took it up the road and there is white smoke coming out of it. what could it be?? Hi well in cold weather any engine will puff out white smoke (steam) gray to black is fuel. and blue is oil. if the white smoke is still there when the engine hot check the fuel for water . if there is you should have a missfire bad running and poor starting. chech for a clean plug. If it runs smooth and dont missfire ,,, dont worry . navi
November 15, 200717 yr Author Hi well in cold weather any engine will puff out white smoke (steam) gray to black is fuel. and blue is oil. if the white smoke is still there when the engine hot check the fuel for water . if there is you should have a missfire bad running and poor starting. chech for a clean plug. If it runs smooth and dont missfire ,,, dont worry . navi yer it runs smooth and dont missfire just puffing white smoke
November 17, 200717 yr Author just found out the problem took the head off and etc, to look at the piston and it has been rubbing against the barrel sleeve.
