FZR400rr wheels
Hi Guys,
Just joined the forum and looks quite well informed. So with that in mind does anyone know if the wheels from a 3en2 will fit, or are the same as the ones on a 3TJ?
Thanks for your help
  • 6 months later...
A bit of a late reply, but I'll post anyway for future reference.
The wheels are different and can only be swapped with some work. - It's only worth putting the 3TJ wheel in the 3EN2 as there is no benefit doing it the other way around.
The 3en2 runs an 18" wheel and 140 rear tyre as standard.
The 3TJ runs a 17" wheel and 150 or 160 rear tyre as standard.
Off the top of my head, I think you have to shave 3mm off the sprocket carrier and machine down the spacer on one side, but make up a wider spacer on the other side (not sure which side is which) to get the chain to line up perfectly.
That's as much as I know, but I'm looking out for a 3TJ wheel to do the swap on my 3EN2 at the moment.
