November 11, 200718 yr Hay there guys just a quick question if you can help. how do i go about adjusting my power valve for best performance, would be gratefull if anyone can help. thanks
January 2, 200818 yr Hay there guys just a quick question if you can help. how do i go about adjusting my power valve for best performance, would be gratefull if anyone can help. thanks adjust the cables from the servo the way that when you turn the key and the servo moves, the little black round thing (where the cables hook on) stops in a position where the small hole is exactly above the hole behind it.
