1ST GEAR CLUTCH RELEASE - BIKE MOVES SLOWLY
ok....finally got all my starting problems solved. and new a new one pops up.
as i release the cluch for 1st gear to engage you can feel take hold, but at a very slow, if not all 100% engagement (hoping this makes sense).
What could it be?
I did a search on this topic but could not find any info.
Thanks.
Robert'
What could it be?
Thanks.
Robert'
Robert
OK this could be a number of things - but first you should check the freeplay at the clutch lever and adjust. You should also check the adjustment on the activation mechanism - usually a worm gear arrangement which should have all the slack taken out - then backed off 1/4 - 1/2 turn. If neither of these make a difference then you could be looking at a problem with the clutch itself - weak springs or a problem with the friction plates. If adjustment does not work then I would advise replacing the clutch components ie springs, friction plates and steel plates.
Good luck
Geoff
:rolleyes:
What could it be?
Thanks.
Robert'
on the engine, clutch side, wind in adjuster as per manual then set free play 1 - 2mm at clutch lever
if no different:- clutch cable not lubed, incorrectly routed, or it could be frayed inside. for the price, buy a new one.
lastly your clutch pushrod could also be bent preventing it returning against the clutch springs.
