76 TY250 won't start anymore
Great forum here ... glad I found it.
my question is this:
I just bought an old 76 TY250 ... it needs work but I love them.
It started first kick when I got it home ... ran it around the property for about 2 mins and then the throttle cable snapped. The oil injector is disabled so the throttle cable is just a single to the carb.
Anyway ... I had a new cable made up ... but now the bike wont start. Maybe 1 out of 10 kicks it catches for just a second then dies.
Pulled the plug and kicked it ... getting what appears to be strong spark every kick.
any thoughts?
Well I solved it.
Rebuilt the carb late last night ....
Removed the wiring harness and cleaned all the contacts ... replaced two connectors that looked a little "iffy"
New spark plug ...
Fires first kick again ...
Now that I know the motor/trans is good it is being stripped completely and getting a ground up resto
im guessing cleaning the points solved the problem
There you go TLC, tender loving care, what more does a Yamaha need!!!
petrol
