silvetti Posted November 2, 2007 Share Posted November 2, 2007 Hi! I just got a 2nd handed Yamaha XJ600N but it has a problem in the engine (nothing that ruins the work, only estetectics). Here is a photo of it... Do you think there's any solution for this ? Cheers! Link to comment Share on other sites More sharing options...
yoda Posted November 2, 2007 Share Posted November 2, 2007 Do you think there's any solution for this ? Cheers! Yes, just tidy the fins up with a small grinder. There is nothing else apart from replacing the head. The loss of fins will not make a big difference to the bikes performance as long as a fairing is not fitted. Link to comment Share on other sites More sharing options...
silvetti Posted November 2, 2007 Author Share Posted November 2, 2007 Thanks for your answer! How much does a engine head for the XJ600 cost ? Would it be easy to find ? Cheers! Link to comment Share on other sites More sharing options...
Moderator drewpy Posted November 2, 2007 Moderator Share Posted November 2, 2007 Hi! I just got a 2nd handed Yamaha XJ600N but it has a problem in the engine (nothing that ruins the work, only estetectics). Here is a photo of it... Do you think there's any solution for this ? Cheers! you can use luminweld rods to build up the fins. being that many it may take a while. you can get them from Frost. Link to comment Share on other sites More sharing options...
Beckie Posted November 3, 2007 Share Posted November 3, 2007 Thanks for your answer! How much does a engine head for the XJ600 cost ? Would it be easy to find ? Cheers! I'm not entirely sure but I do believe parts for the XJ600 are getting harder to come by as they don't make it anymore, not sure of the cost though, sorry! Bec Link to comment Share on other sites More sharing options...
