Posted November 2, 200718 yr Hi! I just got a 2nd handed Yamaha XJ600N but it has a problem in the engine (nothing that ruins the work, only estetectics). Here is a photo of it... Do you think there's any solution for this ? Cheers!
November 2, 200718 yr Do you think there's any solution for this ? Cheers! Yes, just tidy the fins up with a small grinder. There is nothing else apart from replacing the head. The loss of fins will not make a big difference to the bikes performance as long as a fairing is not fitted.
November 2, 200718 yr Author Thanks for your answer! How much does a engine head for the XJ600 cost ? Would it be easy to find ? Cheers!
November 2, 200718 yr Moderator Hi! I just got a 2nd handed Yamaha XJ600N but it has a problem in the engine (nothing that ruins the work, only estetectics). Here is a photo of it... Do you think there's any solution for this ? Cheers! you can use luminweld rods to build up the fins. being that many it may take a while. you can get them from Frost.
November 3, 200718 yr Thanks for your answer! How much does a engine head for the XJ600 cost ? Would it be easy to find ? Cheers! I'm not entirely sure but I do believe parts for the XJ600 are getting harder to come by as they don't make it anymore, not sure of the cost though, sorry! Bec
