2000 R1 normal operating temperature
What are the normal operating temperatures for a 2000 r1?
I was seeing 227 at idle and it was making me a bit nervous...
Just joined.
I have a 2004 R1 and currently working in India. Mumbai to be precise. I note my bike runs extremely hot and I mean hot, especially in stop, start traffic. As long as the fan comes in as required should not be an issue. Tried a short trip in shorts and ended with a red heat rash on my left leg.
Cooling requires forward movement ie airflow though ther radiator. If your sitting still at idle the temperature will go up.
I have a 2000 R1 and my temp only goes up to around 150 at idle, obviously you will have checked the water level and have the correct amount of coolant in ;)
I have a 2001 R1, idle in traffic it's 105, normal riding is around 72.
