RESERVE / ON / PRIME SWITCH
What happens if you leave this switch on prime? Is this bad? I left it on overnight.
Also, if you watch your gas levels is it ok to leave this switch on reserve ??
Thanks.
Hi
Hmmm this could be bad - On Prime gas will flow to the carbs and if the needle valves aren't too good you could end up with an engine full of a lovely mixture of oil and petrol - thats what the guy had done to my Suzuki before I got it - and I had to drain and flush the engine before I could use it!
You might want to pull your dipstick out and smell it to see if any petrol has got into the engine.
Yeah no problem if:
1. Your tank is clean (ie no bits of rust) coz the reserve takes fuel from the bottom of the tank where the cr**p is (you may consider an in-line filter).
2. You do keep a check on fuel as when its gone, its gone!!
Good luck
:rolleyes:
Ok I'm good. Leaving it on run. Thankfully it started.
Robert
Hi
Yeah no problem if:
Good luck
:rolleyes:
Robert
yep keep it on run as there is a vacuum tap which prevents fuel flow when engine is off.
  • 3 weeks later...
you like answering your own posts! :)
I believe this was fitted to prevent flooding the inlet tract ( due to being left on the side stand and the float needle not seating correctly ) and causing a hydraulic lock - lots of damage when you try to start it !
  • 1 month later...
I purely keep it away from reserve if possible because my bike is an older one and I don't trust the tank and I don't have a fuel gauge so it's far too easy for me to run it dry!
