Posted October 24, 200718 yr Question. My XS360, if you are sitting on the bike, which side is do you adjust to change the idle speed ?? Thanks.
October 25, 200718 yr It is a small white cog-sprocket looking gizmo, plastic probably, called the Throttle Stop Screw under and to the rear of the gas tank, at the seat junction. Kind of hard to get to but I adjust mine from the right side. Use a long screw driver if you can't reach it with the fingers. Turn it IN to increase idle, OUT to slow the idle. Mine is a 77 XS360 so I'm sure it is the same.
