Hey guys, my 01 r6 started sputtering. Right around mid throttle, not accelerating, just holding steady, the bike sputters and feels like it surges. Feels like fuel issue, but when i rip on it i get No Hesitation at all. If it were a fuel issue i figure it would get worse when accelerating. Only acts funny when holding a steady speed. Changed the plugs,(needed to be done anyway) checked the gaps before installing. Still runs exactly the same. old plugs were picture perfect, just worn a bit. 13k miles on it now, getting annoying. Hope someone can help me out. Ignition/timing issue? Carbs just need tuned? Thanks again, Patrick
Hi mate it deffo sounds like a carb sync issue have them balanced that should cure it ;)
Hell yeah man, thanks i'll look into it. Sounds expensive, but I guess i'll have to bite the bullet and just get it done.
The cost is around £50 GBP over here so that probably equates to around the $100 mark ;)
Does this spluttering happen at any steady thottle speed or just one part of the band? This could be a problem with the advance/retard electrical timing.
It happens at any steady throttle speed.
I think it must be fuel starvation then.
