Posted October 23, 200717 yr can anyone help my r6 has started to lock the front brake on when im using it the pressure gets more and more until its fully locked on and i have to bleed it to release the pressure!!, ive stripped the calipers and no problems there could it be the master cylinder? also anyone go a exhaust bracket to the frame for a high level scorpion exhaust ive had to bodge one.
October 23, 200717 yr Sounds like the seals on the master cylinder have sprug a leak. Should be simple to do.
