Posted October 22, 200717 yr Is there anybody with ideas i can do with my XT125? The piston bust on it, it has been replaced and rebuilt new rings and rebored. The timing is now back as it should be, but i cannot get it to start, there is no valve damage, and i know that fuel is getting into the carb??? so what now??? please shed a bit of light cos its doin my head in!!!
October 25, 200717 yr Is there anybody with ideas i can do with my XT125? The piston bust on it, it has been replaced and rebuilt new rings and rebored. The timing is now back as it should be, but i cannot get it to start, there is no valve damage, and i know that fuel is getting into the carb??? so what now??? please shed a bit of light cos its doin my head in!!! Was the timing out on it before then? How have you verified it is now correct? What's the compression like? If the timing was out, maybe you did damage a valve. After cranking it over, remove the spark plug and check for petrol on the plug. (Then you can check the spark too. Don't hold the spark plug when you're cranking it though!)
