Posted October 18, 200718 yr Im stumped. My wires are inside my ignition coil and it almost looks as if theyre not supposed to come out. I need to change the wires. Someone out there has done it, right? please send some advice
October 18, 200718 yr Moderator Im stumped. My wires are inside my ignition coil and it almost looks as if theyre not supposed to come out. I need to change the wires. Someone out there has done it, right? please send some advice successfully used this for my xs http://www.xs11.com/tips/repair/repair24.shtml
October 19, 200718 yr Im stumped. My wires are inside my ignition coil and it almost looks as if theyre not supposed to come out. I need to change the wires. Someone out there has done it, right? please send some advice the problem you have there is that they are not supposed to seperate and are infact complete units thought if you suspect that this is the fault have you checked to see if any are loose? also i have see before that this is not the problem that it is the spark plugs either loose or old try changing these first and if the problem persists try Ebay for the coils they arnt usualy that expensive hope that helps good luck
