Does anyone know how to change spark plug wires in '90 fzr600??
Im stumped. My wires are inside my ignition coil and it almost looks as if theyre not supposed to come out. I need to change the wires. Someone out there has done it, right? please send some advice
successfully used this for my xs
http://www.xs11.com/tips/repair/repair24.shtml
the problem you have there is that they are not supposed to seperate and are infact complete units thought if you suspect that this is the fault have you checked to see if any are loose? also i have see before that this is not the problem that it is the spark plugs either loose or old try changing these first and if the problem persists try Ebay for the coils they arnt usualy that expensive hope that helps good luck
