October 14, 200718 yr Hello all can anyone tell me are if the vin number on my bike a dt125r should be the same as the frame number as the frame has been resprayed and the vin sticker removed . thank you.
October 16, 200718 yr Hello all can anyone tell me are if the vin number on my bike a dt125r should be the same as the frame number as the frame has been resprayed and the vin sticker removed . thank you. I thought these were two terms describing the same thing. You'd hope that the VIN/frame number would be stamped to the frame and difficult to remove or change. Does your frame number match what's on the V5 (log book)?
October 16, 200718 yr Author I thought these were two terms describing the same thing. You'd hope that the VIN/frame number would be stamped to the frame and difficult to remove or change. Does your frame number match what's on the V5 (log book)? Hello jinxed thanks for the reply i thougth they were the same but some one said. some thing that made me begin to think i was wrong.
