ive just brought a fzr250r and the tank has got crap on the inside of it i was wondering if there was ant way of getting it out without cutting the tank in half :D
an old chain and some diesel.
if you can handle it, acid.
What sort of cr@p? (There's a question I thought I'd never ask!) Could it be rust? If so, you may need to line it or even replace it if it's bad.
Presumably, you've removed the tank already and given it a good shake with a little petrol in before emptying it out? (To try to clean the tank out.) This is a plastic or steel tank?
