Posted September 27, 200718 yr Greetings from the Cape Fear, A question for you good folks. When rolling on the accelerator, the rpms make a jump from idle to idle plus a bit more than I want. I can't seem to ramp up. Is this a characteristic of fuel injection or electronic ignition? Is something out of adjustment? TIA, Bill
September 27, 200718 yr Do you mean that if you start up your bike and have it in neutral and give the throttle a couple of twists that it will idle higher when you let off the throttle?
September 27, 200718 yr Author No, I'll try to explain better. Imagine the rpms increasing in a range from one to ten. When I twist the throttle for a one nothing happens. If I continue to twist I'll get a two. Cornering is more difficult than it should be.
September 27, 200718 yr Author Thanks, I'll do that. But... 1. I don't have a good feeling about the dealer. 2. I'd like to know a bit about the system. Can you direct me to more information about it? Bill
September 27, 200718 yr I think that is a problem with the throttle sensor for the ECU. However it could be the ECU mapping and should not happen. You could try and find others with that type of engine and find out if they have the problem but as such that will not help you. Check that the position sensor is registering the actual throttle movement and that any cables both electrical and actuating are in good condition. There should be very little play in a actuator cable to the throttle bodies. Would be interested to find out why this has happened!
September 27, 200718 yr Author Hey Yoda, Thanks for the suggestions. I'm going to start with a Google search and find a tech manual for the bile. I like to work my way through problems for several reasons. WB
September 27, 200718 yr Author Hey Yoda, Thanks for the suggestions. I have the tech manual for the bike. I'll start reading. WB
September 27, 200718 yr Author I am not getting a fault light due to the ECU detecting a problem. I have a digital voltmeter, but I do not have the throttle coupling. So, at this point, I cannot check the throttle position. Some 'play' is built into the throttle grip. I have participated in operator error problems before. I'll give this more consideration. WB
October 15, 200718 yr Is anyone getting some kind of CLUTCH rattle? sounding like its chattering " chata chata chata" is this normal when in neutral and clutch released?. distributor mechanic says its normal with this bike, but it just sounds a little loud to me for it to be normal.
October 15, 200717 yr Is anyone getting some kind of CLUTCH rattle? sounding like its chattering " chata chata chata" is this normal when in neutral and clutch released?. distributor mechanic says its normal with this bike, but it just sounds a little loud to me for it to be normal. according to everyone it is normal mine does it but is getting better with milage, alot of guts have expressesd the same concern so that tells me it is normal, i have only heard of one guy who had there clutch go out. i thought about draining my oil and adding synthetic but i am told not to till 10,000 miles so i will wait
October 20, 200717 yr Im coming off a 2006 Sportser 883. I noticed a throttle issue right away. The yammy dealer found that the windshied was kinking the throttle cables and free play needed to be adjusted. Im still learning how to corner on this bike. Used to be in 2nd on the sporty .. doesnt work here lotsa lugging .. in fact I can ride along at 55 in 4th and the bike isnt screaming. Another fact is that if I try to shift to 5th before being at, at least 62, I lug it. Now its gud ... it still will take a while to get used to the FI throttle response. Chris
