1977 Yamaha XS360D2. I've had the carbs cleaned and adjusted, new plugs and points, valves adjusted and timing set.
On the first start of the day it takes a minimum of a dozen kicks to fire it up. I've tried Choke , No choke, even Prime.
Doesn't seem to make any difference. After the first start , it starts and runs fine the rest of the day ???.Now I wonder if the local bike service guy knows what he is doing or actually did the work I paid for. I may have have to go talk to him with a tire iron..!.. Any suggestions sure will help..
should just fire right up on first kick! mine does (on half choke in UK summer)
why don't you get a manual and have a go tuning it yourself as its pretty easy and you'll get a lot more enjoyment from your bike!
If any timing etc is wrong It'll be a bugger to start, whats the power like and how smooth is the engine?
get a compression check .
The power seems to be OK, good pick up thru the gears. No smoke. I think your right about doing it myself. I've worked on my own cars so I may as well get educated on the bike. At least a person knows what has been done or attempted untill it is right.
Thanks for the reply drewpy !!!!
no problem, do a forum search for online manuals as I must have listed them a few times
Drewpy
Good advice on the manuals,, I'm on it !! . I have a Yamaha XS360 with 2D supplement shop manual on the way. I just received the Clymer 1976-78 manual. A Haynes manual on CD. Also have a Parts manual on the way. If I don't learn something from all this, I'll go sit in the corner !!.
Thanks again drewpy, your a good man to have around. I don't know about that handle you use, don't sound drewpy to me. :P
you should speak to the wife ;)
