September 10, 200718 yr Hi all, as yamaha have used these awsome brakes on so many different bikes someone must be able to help! (i hope) How difficult is it to service the calipers, do you need a special service tool to remove the outer piston plugs(the gold spot bit) or can all the seals be changed with just the piston pushed back into the caliper?? If it makes a difference they are calipers of a 2003 R1 Any help would be great, Thanks Sam
September 11, 200718 yr Hi all, as yamaha have used these awsome brakes on so many different bikes someone must be able to help! (i hope) How difficult is it to service the calipers, do you need a special service tool to remove the outer piston plugs(the gold spot bit) or can all the seals be changed with just the piston pushed back into the caliper?? If it makes a difference they are calipers of a 2003 R1 Any help would be great, Thanks Sam go on to EXUP1000.co.uk dont know how to post link but there's quite a lot about calipers on this site
September 11, 200718 yr Author go on to EXUP1000.co.uk dont know how to post link but there's quite a lot about calipers on this site Ta mate, ill have a look and see what it says! Thanks Sam
