Posted September 5, 200718 yr Hello again, as i mentioned in a previous post, my gas tank has some rust scale in it, and i am going to need to clean/treat/seal it. have any of you done this yourselves with some of the chemical treatments out there? would it be more worth it to have someone else do it (i was quoted 87.50 to clean and seal). also, im having a hard time finding replacement petcock gaskets for where it connects to the tank. is there a liquid gasket material that i could use for this? *edit* i didnt bother to check the yamaha site because i assumed it had been discontinued like everything else for this bike, but they carry the gaskets. what i need now is the outer gas tank gasket, because mine is in pretty bad shape and leaks.
September 5, 200718 yr Moderator Hello again, as i mentioned in a previous post, my gas tank has some rust scale in it, and i am going to need to clean/treat/seal it. have any of you done this yourselves with some of the chemical treatments out there? would it be more worth it to have someone else do it (i was quoted 87.50 to clean and seal). also, im having a hard time finding replacement petcock gaskets for where it connects to the tank. is there a liquid gasket material that i could use for this? gasket from here POR 15 is the stuff you want for sealing, check the prices and compare with the quote.
September 6, 200718 yr Author gasket from here POR 15 is the stuff you want for sealing, check the prices and compare with the quote. thanks, found the gaskets, was able to order them already. for the por 15, isnt that a paint on? i dont need to seal the outside of the tank, i was just wanting to seal the interior of the tank once it has been cleaned.
September 6, 200718 yr Moderator thanks, found the gaskets, was able to order them already. for the por 15, isnt that a paint on? i dont need to seal the outside of the tank, i was just wanting to seal the interior of the tank once it has been cleaned. try here
September 6, 200718 yr http://www.frost.co.uk/item_Detail.asp?pro...=&subCatID= have a read of this link for your tank (think i'm gonna do mine soon with this)
