September 4, 200718 yr Hi All anyone suggest a goog product to remove rust fron chrome?? With Thanks Hadley
September 9, 200718 yr Hi All anyone suggest a goog product to remove rust fron chrome?? With Thanks Hadley I have found 00 steel wool to work pretty well in most cases if you don't get to rough with it. I've also used a fine brass wire wheel in my drill for faster work on larger areas. Just make sure you don't spend too much time in one spot and only press lightly or it can eat right through the chrome.
