FZ6 Fazer vibration
Help!!! I have a 2006 faired fazer 600 and above 80 mph i gat a lot of vibration through the handlebars, more so when 2 up does anyone else hve the same problem or even a cure :o:o:o
You need to be more objective about the vibration.
Does it always happen on the same road or route?
Is it with the same pasenger?
Have you checked the balence of your wheels?
Have you forgotten to fully service your front forks?
Have your steering head bearings failed?
Is the rear wheel in line?
Is the front disc warped?
Are you using more rpm than normal?
Are the rear bearings worn?
Are the swing arm bearings worn?
Have you fully checked your tires (tyres) for wear or blisters?
All these and other questions YOU will have to answer.
