Thundercat RPM is freaking out
Hi guys and gals,
Need help.My thundercat as and RPM issue.And goes up to 8000 when on neutral then goes back down to zero and goes back up and again this during the entire time im riding.Seems like a bad conection or something can anyone tell me where is the RPM sensor or cable on the bike so i can find it and test it out.Ive looked but cant find where it plugs in the motor.
Thanks for infos
Dan
Common fault with the cat, and is part of the diagnostics system.
What it's saying is that there is a problem with the fuel sender. Usually it doesn't need replacing but can be fixed by soldering on the wire that breaks loose. You will need to have an emptish tank, take you tank off and tip it upside down on to some soft non scrath padding and then remove the sensor the broken wire is hidden away inside the tank.
  • 3 months later...
think 7000 is the low fuel warning light which is the elec plug from bottom of tank it might be dirty or loose if you had tank off
8000 is exup valve sticking
3000 is the TPS
7000 is the Exup (not relevant to Thundercat but is to Thunderace)
8000 is the Fuel Level Sensor
It's very common for the wire on the actual sensor to break free and a simple solder repair sorts the problem.
