de-restrict dtx 125
ive just bought a brand new dtx 125 (supermoto) and i need to know how to de-restrict it, is there anything different from the older models, as it has digital clock and im not sure about it having a powervalve.
  • 2 months later...
Remove rubber airbox snorkel which you will find under the seat. Have exhaust system completely gutted out or invest in a DEP exhaust system. Go up two sizes on the main jet and you're set.
  • 3 weeks later...
hi dtxracer i have just bought a dt125x..& have fitted d.e.p. exhust system modified airbox,ignition retard disabled(allows powervalve to open fully)iridium sparkplug,15 tooth gearbox sprocket..hope this helps alza
Hi alza I've also got a dt125x and waiting for the DEP to arrive :D love the bike, just want a little more power, what do you mean when you say 'ignition retard disabled' ? Thanks
There's word of a green wire behind the clock surround which needs earthing. Think that could be what he means.
Oh right thanks, yea i've seen posts about that on the internet, anyone got any info on how and where best to earth this wire ? or if it even works doing this ? Any help would be really appreciated :D
Earth it anywhere metal. Frame would be a good spot if you can find somewhere.
  • 3 weeks later...
hi laze yeah Willenium is right you earth the wire to the frame..thats the way mine is done!!alza
Oh right thanks a lot for the help i'll have a look at doing this wire mod soon. Does it make much of a difference to the bike ? Thanks
