August 31, 200718 yr I am having an issue with my 04 yzf600. I adjusted the clutch lever so that it is up to manufacters specs. now it engages really late, like the lever is almost stopped before engaging. is there an easy fix for this? the bike does not even have 9k on it.
August 31, 200718 yr Moderator Sounds like you need to adjust the cable @ the clutch end & then re-adjust it @ the lever for freeplay
September 6, 200718 yr Author there is no adjustment at the clutch end.... is there anything i can do?
