1974 DT 360 Runs then dies
I have two 1974 Yamaha DT 360 enduros. Both will start and run clean for around 3 seconds and then die. The carbs have been cleaned the fuel and plugs are new. all lighting and kill switches have been disconnected. Both bikes do exactly the same thing. Has any one experienced this. I am not very good at wiring. I have an ohm meter but do not know how to use it. Can any one help? Bill
Sounds more like a fueling problem.
They are starting on a rich mixture and when the amount of fuel reduces for normal running they are cutting out.
Service the carbs and check the fuel filters for blockage.
  • 2 months later...
I have done some more research. The dt 360 will produce exactly three sparks and then quit firing until I have waited 24 a couple hours. It will then produce exactly three more sparks before quiting. I have exchanged stators coils and cdi units. All with the same results. The carbs have been cleaned and the plugs have been changed.
quote name='yoda' date='Aug 29 2007, 03:51 AM' post='44383']
