need advice my sr 125 failed mot today on steering beerings is this a big job bike is 10 years old good nick only done 11000 miles been told £120 to fix not sure what to do
Hi,replacing head bearings is a straightforward job,should take at most a mornings work,if you are a bit mechanical thaty is,parts should be a few quid,about twenty if you go for the tapered bearings,where abouts in uk are you?
cheers
Buzz
hi ,this is not a big job .but if you have little nowlege,it is easy.best get a manuel that shows you everiting ,good luck.
GUEV>
