Bill F Posted August 16, 2007 Share Posted August 16, 2007 I purchased the Acumen DG8 Universal Gear Indicator for my 1999 Royal Star Venture and found the wiring easy except for the tacho pulso wire (this bike does not have a tachometer). I was searching around the pick-up coil and ECU for the wire that would give the pulses that would be necessary to operate the Indicator but never found it. However, I did really cause myself a lot of problems while down there. First, I popped one of the 30A fuses, then I noticed that the headlight fuse was blown (red wire with yellow trace). No matter what I do, I can not keep that 15A headlight fuse from blowing. I have searched everywhere for the short that is causing the problem. Does someone have a solution for both of these problems? Bill Link to comment Share on other sites More sharing options...
nwoody Posted August 26, 2007 Share Posted August 26, 2007 I purchased the Acumen DG8 Universal Gear Indicator for my 1999 Royal Star Venture and found the wiring easy except for the tacho pulso wire (this bike does not have a tachometer). I was searching around the pick-up coil and ECU for the wire that would give the pulses that would be necessary to operate the Indicator but never found it. However, I did really cause myself a lot of problems while down there. First, I popped one of the 30A fuses, then I noticed that the headlight fuse was blown (red wire with yellow trace). No matter what I do, I can not keep that 15A headlight fuse from blowing. I have searched everywhere for the short that is causing the problem. Does someone have a solution for both of these problems? Bill have you got brighter bulbs in your headlamps. if so change them to originals. try that ok Link to comment Share on other sites More sharing options...
