Posted August 11, 200717 yr I recently purchased a 2001 yamaha V star 650, today coming back from the flea market, it started slipping some when you get on the gas. If you slowly go into it, no problems, when you get on it, it takes a second or two before it engages. Anyone know what may be up with this, driveshaft, or transmission. Looks like I posted this in the wrong forum, if a mod or admin would move it to the technical forum, I'd be gratefull.
August 12, 200717 yr Could be alot of things the easiest is bad gas dump replace it and try a good carb cleaner. Then you can adjust the clutch cables if that does not help
