lesm Posted August 9, 2007 Share Posted August 9, 2007 having been sat a while I got the old bike out of the shed fresh fuel, batt and plugs. after a few days I discovered that the remote throttle stop screw was usless so I improvised with a small bolt, which holds it in the right place, however when I start it up it backfires then settles its self to a steady 1000rpm,s then for some reason revs its self to 3500rpm,s and sits there, the throttle linkage does not move so I'm at a loss as to why it does this. anyone got any ideas? les Link to comment Share on other sites More sharing options...
yoda Posted August 9, 2007 Share Posted August 9, 2007 You either have a sticking throttle cable or you have an air leak after the carb. Try the cable first. Link to comment Share on other sites More sharing options...
lesm Posted August 9, 2007 Author Share Posted August 9, 2007 You either have a sticking throttle cable or you have an air leak after the carb. Try the cable first. cheers yoda took carbs off (again) cleaned them put back on tight seems to have cured rev prob, lost me bolt again so hand held revs only, but seems okay cheers. les Link to comment Share on other sites More sharing options...
