Help with PW80
Please help, I recently bought my son his first bike, a 2003 Yamaha PW80. He loves it but all of a sudden we started having problems. It is very hard to start now, I have to drain all the gas out of the carb before I can kick it over. When it does start it won't idle at all. You have to keep the throttle open a little or it will die. The worst part is that it now blows oil out the tail pipe! I mean alot of oil, it will cover a 2 or 3 square feet area behind the bike.
Please help don't know what to do and my son really loves going out and riding.
Thanks!
Hi
Sounds like one of the oil seals has gone.
Is the bike using 'gear-box' oil ?
If you can't get it to idle it could be an air leak in one of the seals on the Power Take Off side - but if it is using oil it sounds like a gearbox seal.
Check the spark plug for colour to see if it is oil fouled - if necessary disconnect the auto-lube system (if it has one) and use a 20:1 mix in the tank - see if that makes a difference.
If its an oil seal - fraid its and engine dismantle job - but they are not too difficult on the small engines - and if you are going that far I would consider doing the bearings at the same time.
:D
Thanks, I have removed the top end and bought new piston and rings. I should be finished with the re-build by this weekend. The plug was burnt so I purchased a new one. If this is not the fix I will move on the the Oil Seal.
