Amount of oil
Hi,
I have XJ 900 58L -89 and I changed oil today; but why does the stick in the little window shows that it´s full after 1 liter? Can I fill up with 1,5 liter or what...? TIA
/Raster
Hi,
/Raster
you have to allow for the oil filter being empty of oil after an oil change especially if you changed the filter as well , which is allways reccomended to do so, or the clean oil is just running through a dirty oil filter.if you run engine the filter will fill with oil and the level will go down.
