July 21, 200718 yr I have a 2000 V Star 1100 Classic. Just recently the regulator/rectifier overheated and melted part of the connector/plug in on the bike wiring. Does anyone knoe where I can find another connector/plug? It also metled the plastic where the regulator/rectifier is mounted. Any suggestions on relocation, mounting alternatives, etc? Thanks
July 21, 200718 yr Moderator I have a 2000 V Star 1100 Classic. Just recently the regulator/rectifier overheated and melted part of the connector/plug in on the bike wiring. Does anyone knoe where I can find another connector/plug? It also metled the plastic where the regulator/rectifier is mounted. Any suggestions on relocation, mounting alternatives, etc? Thanks http://www.vehicle-wiring-products.eu/VWP-...iconnectors.php http://www.autoelectricsupplies.co.uk/category/1
August 14, 200718 yr http://www.vehicle-wiring-products.eu/VWP-...iconnectors.php http://www.autoelectricsupplies.co.uk/category/1 Dunno if they can help but a good company for electrical items (an they carrie quite a few for the cruisers at half the Yamaha prices is a company called Electrics 0149 1682369 they may be able to help with the plug.
August 14, 200718 yr Before you re-assemble the plug and wiring, you should take a look at what caused the failure in the first place. it has failed under heavy load which means that another component is drawing too much current. Dont risk a fire.
