July 2, 200718 yr hi all. im darren from newcastle,australia, i own a trx 850 & would like to fit one of those tank mounted camera brackets. to order this unit i need to know what has the same space bolts on a fuel cap the same as mine??????? my spacing is 35mm from the centre of each bolt. it mounts using 3 bolts & the space from the 2 outer mounted bolts are 63mm..,... http://www.sportbikecam.com.au/ this is the braket im talking about. so i need to find out what other bikes have this bolt spacing cause my bike dosnt register, cheers all daz from aust
