Posted July 1, 200718 yr hya people i wonder if there is anyone who can pinpoint my problem the problem is always there but is really noticeable at night.. while riding my electrics surge all my lights including dash headlight become really bright for a few seconds then return to normal and sometimes they dim below normal level too it fluctuates all the time would i be right in thinking it could be the voltage regulator or is there any other possibilitys ??? because i dont really want to go on an expensive fault finding saga i hope there is a member who is better on electrical than me any help would be really appreciated ps i get the feeling people laugh at my xj because its often termed as a divvy and i gotta say its starting to put me off it now shame really cause i like it even though its a bit dated compared to some like the bandit
July 1, 200718 yr hya people i wonder if there is anyone who can pinpoint my problem the problem is always there but is really noticeable at night.. while riding my electrics surge all my lights including dash headlight become really bright for a few seconds then return to normal and sometimes they dim below normal level too it fluctuates all the time would i be right in thinking it could be the voltage regulator or is there any other possibilitys ??? because i dont really want to go on an expensive fault finding saga i hope there is a member who is better on electrical than me any help would be really appreciated ps i get the feeling people laugh at my xj because its often termed as a divvy and i gotta say its starting to put me off it now shame really cause i like it even though its a bit dated compared to some like the bandit Hi there. I'm not an expert on Diversions specifically! Can you say how quickly the fluctuations occur? i.e. what's the approximate frequency? M/cycle electrics tend to be fickle at the best of times due to the harshness of the environment in which they have to operate. Bear in mind that it's meant to be a DC system and what you're seeing smacks of AC. This would seem to suggest either a voltage regulator problem (is is mechanical or solid state?). Possibly a diode pack problem or maybe a flattish battery which is exhibiting a higher than usual superimposed AC ripple. Kind regards, Chris Heath
September 13, 200717 yr Author wow thats gone over my head lol i have changed the voltage regulator and its still there the battery is nearly new too no sure what to check next or where either ???
September 13, 200717 yr Check the earth on the engine/frame and battery connections first. These should be good, clean and not loose. Always check the lowest common denominator first!!
