Have a 1980 XS400GS
@ high speed 50-60 it loses power
i.e. run @ 60 for a minute then drops down
New plugs,wires & had Carbs Cin'ed
Does it happen no matter what gear you are in? Whats you throtle position and what RPM are you at. You might need new coils or condenser. If you're tuning it you might as well get them for added peace of mind they're fairly cheap. go to MikesXS.com. A lot of parts for the xs650 will work with the 400. I checked the part numbers for the coils and they are the same between the two bikes. And if you're running point make sure to get non resistance or 1ohm resistance plug caps, you need as much spark as you can get with points.
55 @ 5000 RPM
the plugs coil wires & coil wire end are new from yamaha
the throttle is open all the way
55 @ 5000 RPM
check fuel flow from tank and it is venting (replacing the space left by the fuel with air)
then check float heights in each carb
check the timing is set correctly, it could be slighly out which is commn on the 250/400
regards
Just a add-on
in 5th gear can run it to 6500 PRM = 55MPH but thats it
if I shift to 6th gear it drops to 5000RPM = 50 PRM & no more power
