Seat removal and fuses
I have a yamaha yzf 600r. I was trying to reconnect the turn signal lights and i think it blew a fuse. I was unable to get a service manual for the bike so i need help figuring out where the fuses are and how to get the seat off of the bike. I know there are two screws on the side but something else is still holding it in pretty well. Any help would be appreciated i want to get it back on the road asap.
Isn't the seat held on with a lock? Is this an R6 or a Thundercat?
I guess it would be a thundercat. I know it is not a yzf r6
Ok...I thought there was a keylock that holds the seat on
The fuses are located under the seat
If you look on www.ronayers.com you will be able to look at online microfiches that show where these things are.
Thundercats have a lock for the seat under the pillions left footrest, should be the same as the ignition key... turn one way to open helmet lock, one way to open seat lock.
