June 22, 200718 yr I have bought a XT600 (3TB) which has had a different right hand side engine cover fitted and so the oil feed pipe has been modified to take the feed off the bleed screw at the oil filter. Is this modification sufficient? Also, does this motor need an oil cooler? Thanks
